Author Topic: hi i have a problem with my golf gti 1.8 turbo 2000  (Read 3339 times)
Offline prodigy28
« on: 24 January 2009, 20:55 »
started about a week ago (after finally getting the electrics sorted after 3 months)i noticed the car whilst driving along would lack power ,it sometimes cleared if i put my foot down or if i dropped down a gear,over the week though it got worse and was doing it all the time(missfiring/spluttering),even when car is not moving,put it down to spark plugs,had 4 new ones fitted still same problem,(basically only running on 3 cylinders),,unscrewed each plug individually and started car and realised there was no spark from number 4 cylinder,on my car there is an individual coil pack for each cylinder/spark plug,bought a new one for cylinder number 4,,fitted that and now have spark from all plugs,but the problem is still there,not quite as bad,more so when moving slowly or reversing,,any clues im new to the forum,any ideas would be appreciated,mark
Offline prodigy28
Re: hi i have a problem with my golf gti 1.8 turbo 2000
« Reply #1 on: 24 January 2009, 20:59 »
sorry i posted it originally in wrong section,
Offline T_J_G
« Reply #2 on: 24 January 2009, 21:00 »
MAF?
Offline richw911
« Reply #3 on: 24 January 2009, 21:16 »
Offline prodigy28
« Reply #4 on: 24 January 2009, 21:50 »
hi/
many thanks for quick responses,i will give this a try,,,will let you know the results,,mark
« Last Edit: 24 January 2009, 21:53 by prodigy28 »
Offline T_J_G
« Reply #5 on: 24 January 2009, 21:51 »
uplug it first and see how it runs mate;) Think they're about £80 not too sure though.
Offline richw911
« Reply #6 on: 24 January 2009, 21:51 »
hi/
many thanks for quick responses,i will give this a try,whats the cost roughly for a new maf sensor?,,will let you know the results,,mark
Not cheap - 80 pounds IIRC  :smiley:
Offline prodigy28
« Reply #7 on: 24 January 2009, 21:55 »
thankyou both for quick replies,, :smiley:
Offline T_J_G
« Reply #8 on: 24 January 2009, 21:56 »
hi/
snooze you lose ;)
Offline richw911
« Reply #9 on: 24 January 2009, 21:56 »
Also get it on vag com or a code reader to see if she throws any codes up before you buy anything  :wink:
