Author Topic: Disconnecting Alarm Siren  (Read 4975 times)
Offline VW_UK
  • 2000 (X) Mk4 TDI S for sale. £2250
« on: 24 January 2009, 18:23 »
Is it possible to disconnect the alarm siren and just have the lights flash if the alarm is triggered?
Also where is the siren located?
Offline MaXXeH
  • Golf MK5 GTI
Re: Disconnecting Alarm Siren
« Reply #1 on: 24 January 2009, 23:54 »
Yes you can, it is under the bit where the ecu is, u just unplug it  2min job.   dont no y vw done this so easy to disable it :(
Offline VW_UK
« Reply #2 on: 25 January 2009, 13:09 »
I've read somewhere I have to remove the wipers and the plastic bit to get to it.
Is there any other way?
And does it just plug out? I'd like to be able to reconnect it again once my bootlid is fixed and don't want to have to cut wires etc.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 25 January 2009, 16:04 »
yes you do need to remove the wipers and plastic be very carefull with the plastic cover as very easy to break it as it's so tight
