Author Topic: pas  (Read 1479 times)
Offline blackdragon
pas
« on: 24 January 2009, 17:43 »
my steering in squealing on tight turns, any suggestions?
Offline daniel-1986
Re: pas
« Reply #1 on: 24 January 2009, 18:18 »
possibly the power steering pump
Offline filthy
Re: pas
« Reply #2 on: 24 January 2009, 19:21 »
Probably a knackered belt, they wear out and start to slip (and squeal)
Change the belt first (it's cheap) then start looking at the expensive bits...pumps will squeal when they are knackered, but the chances are that if it's suealing, it probably won't be pumping very well...
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Uruk Hai
Re: pas
« Reply #3 on: 24 January 2009, 19:26 »
Make sure the belt is tight enough beofre you do anything else  :smiley:
Offline blackdragon
Re: pas
« Reply #4 on: 24 January 2009, 19:51 »
is that hard cos i'm a girl :rolleyes:
Offline filthy
Re: pas
« Reply #5 on: 24 January 2009, 20:03 »
Dead easy, 3 bolts to undo, best get a haynes manual to explain it...
Offline Ben Lessani
Re: pas
« Reply #6 on: 24 January 2009, 21:22 »
Offline blackdragon
Re: pas
« Reply #7 on: 25 January 2009, 09:22 »
thanks am gonna have a look tomorrow
Offline sparkplug
Re: pas
« Reply #8 on: 25 January 2009, 10:40 »
check the power steering fluid level too.
1986 GTI atlas grey
