Author Topic: oh no !!!!!!!!!  (Read 1843 times)
Offline sidecarphil
oh no !!!!!!!!!
« on: 24 January 2009, 14:10 »
now the trusty old 1.3 has gone wrong
WHY
dloody brake servo has split and every time the Mrs brakes it hisses like a snake and stall's the engine
GRRRRRRRRRRR
as if i don't have enough to do !!!!!!
Offline maxp
  • J reg 8v digi gti
Re: oh no !!!!!!!!!
« Reply #1 on: 24 January 2009, 16:19 »
handbrake with style
Offline sidecarphil
Re: oh no !!!!!!!!!
« Reply #2 on: 25 January 2009, 00:32 »
i'll have a right leg like arnie by the end of the week
and i think my Mrs will be keeping my GTi !!!!
sh1t
Offline sidecarphil
Re: oh no !!!!!!!!!
« Reply #3 on: 26 January 2009, 11:57 »
got a GTi servo and master cylinder from a scrappy's
will it fit ??
how hard is to fit ??
please tell me it's not a dash out job  :shocked: :shocked:
Re: oh no !!!!!!!!!
« Reply #4 on: 26 January 2009, 12:50 »
gti servo will fit but you might have to fit a rear brake compensator!  this is the only real difference between 1.3/1.6 and 1.8 models, and 1.8s all got a compensator.
edit: not a dash out job, take the lower dash trim off and undo the 4 nuts behind the brake pedal, and the clip holding the pedal to the servo.  Then go back to engine bay and undo 2 nuts holding master cylinder on, carefully pull it forward.  Brake servo can then be removed & swapped, without cracking loose the master cylinder pipes and therefore without bleedign the brakes.  I managed it on a RHD GTI so you should have no trouble  :grin:
« Last Edit: 26 January 2009, 12:52 by rubjonny »
Offline Mew
Re: oh no !!!!!!!!!
« Reply #5 on: 26 January 2009, 12:54 »
This would actually be quite a nice job compared to a RHD car!
Offline sidecarphil
Re: oh no !!!!!!!!!
« Reply #6 on: 26 January 2009, 14:43 »
thought all 1.8s have rear discs though ???
hense the compensator :undecided: :undecided:
Re: oh no !!!!!!!!!
« Reply #7 on: 26 January 2009, 15:09 »
1.8 carby models have rear drums. they have the 9" servo and so need the compensator, whereas 1.3 and 1.6 models have a smaller 7" servo, and dont.  At least here in the UK, europe could be different i guess ;)
edit: actually the reason may be down to the wheel cylinders in the drums, AVS recons models with the compensator had bigger ones :)
« Last Edit: 26 January 2009, 15:11 by rubjonny »
