Author Topic: Immobiliser Transponder in Key...  (Read 2590 times)
Offline banburyv6
« on: 22 January 2009, 15:19 »
Hi,
I recently bought one of those fake key cases off eBay to replace my battered and selotape-covered spare key (if you're interested - they're actually pretty good: link).
I set about transferring all the important bits to the new case, key blade, remote electronics, all went smoothly.  That is until I came to remove the immobiliser transponder from the original key.  It was glued pretty solidly into the body of the old key and, like the idiot I am, I set about it with a screwdriver...   :rolleyes:
You can probably tell what's coming next    :smiley:
On removing the transponder I realised I'd cracked off a bit of the glass covering, but I figured it would probably still work so put it into the new key case.  Lo and behold it doesn't still work at all, and the engine only starts for a second before turning off and whinging about the immobiliser.
Is there anything I can do about this?  Are there any ways I can get a new chip and code it it the immobiliser without going through the stealers for a complete new key and paying hundreds?
(Before anyone suggests it, yes I have considered removing the working transponder from the other key and taping it under the dashboard... shortly before realising what a stupid idea that would be...  :laugh:)
Any advice gratefully received!
Cheers,
Ed
Offline old_n07
Re: Immobiliser Transponder in Key...
« Reply #1 on: 23 January 2009, 19:49 »
Have a word with Kalu on UK-MKIV's he might be able to get a crypto chip but failing that you will need a new key (bottom half) and have it coded to the car
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline banburyv6
« Reply #2 on: 24 January 2009, 14:07 »
Thanks I will have a go contacting Kalu.  I think you mean top half of key though, that's the bit with the transponder chip in it?  Hopefully I can get it sorted without it costing hundreds (just had new bushes, service, haldex oil/filter, clutch master cyl... can do without much more at the mo!)   :smiley:
Cheers,
Ed
Offline old_n07
« Reply #3 on: 25 January 2009, 12:24 »
Nope, I meant bottom half - the bit with the key blade attached is where the transponder is. The top half is the remote.
If you do get a new lower half make sure you get an un-used (new) one not second hand as if your car is immo 3 the key can only be coded to one car so if it had neen used before it won't work in your car.
Neil
« Last Edit: 25 January 2009, 16:55 by old_n07 »
Offline dubcruiser
  • Audi A3 SB S-Line 2.0T Quattro 2007
« Reply #4 on: 25 January 2009, 15:45 »
Yeah its the bit where the button is to flip the key out (also where the VW badge sticks to on the other side!)  :smiley:
Scott
Golf GTi 180bhp 6 Speed 2003, Tornado Red, Electric Sunroof, Climatronic, Winter Pack, Black Leather, Santa Monica Alloys, Centre Arm Rest, 6 Disc Changer, R-Tech Remap (Now Sold)
Audi A3 Sportback S-Line 2.0T Quattro 2007, Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, Auto Lights, Auto Wipers, iPod Prep, Interior Light Pack
Offline banburyv6
« Reply #5 on: 26 January 2009, 12:13 »
Yeah - we're all talking about the same bit, I thought that was the "top" of the key but I guess it depends which way up you hold it   :grin:
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 26 January 2009, 12:29 »
I know I shouldn't laugh but... :laugh:
hope you get it sorted fella :afro:
