Author Topic: Driveshaft question.  (Read 737 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 21 January 2009, 20:21 »
Just a quickie! The banana washers that sit behind the driveshaft spline bolts...are they required or can I use normal washers of the same thickness???
Offline DarnPB
  • Formerly Darnpistonbroke
Re: Driveshaft question.
« Reply #1 on: 21 January 2009, 20:33 »
I don't see any problems with fitting washers. Why, have you 'misplaced' one? Don't mix washers and 'banana' washers as you call them. You could end up with an inbalance and thus vibration.
« Reply #2 on: 22 January 2009, 10:58 »
I expect the banana washers are there to help spread the load?  If vw fitted them then I would do the same, some things you shouldnt take risks with :)
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 22 January 2009, 11:28 »
Not only are they 'shaped', they also have ridges which help lock the bolt.
Don't fit plain ones.
