Author Topic: double wobber  (Read 1183 times)
Offline sidecarphil
double wobber
« on: 21 January 2009, 19:02 »
Offline sidecarphil
Re: double wobber
« Reply #1 on: 25 January 2009, 01:15 »
also copied from there
 Listing of the most common defects
Thermo defective switches
cracked belts
porous water hoses
faulty heat exchanger (from VW has been repaired free of charge)
Corrosion in the headlights
Corrosion at the cable connectors
defective lighting equipment (55-hp engine)
uneven hand brake
cuff tear of the drive shafts
worn wheel bearings
defective drive shafts (older models)
 Porous rubber window (older models)
porous brake lines at the front axle
ausgeleierte throttle valves (GTI)
Conservation expiring at the tailgate (improved in newer models)
Lighting failure in the heating panels
brake lever
Rust under the tailgate handle
HMMM interesting
we take these "defects" as normal driving for an old car , nice to see they were factory fitted
