Author Topic: Help! Mk3 golf gti headlights not working!  (Read 2963 times)
Offline mattyass
« on: 20 January 2009, 19:45 »
Ok so i got in the car to drive home from work tonight and thought hmm my bulbs aren't that bright i need to change them. Pulled over to look and found out my headlights were not working at all. Sidelights, full beam, indicators, fogs, all working fine. Seems like an odd problem.
Has anyone had any experience of this? can anyone shed any light on the prob? (scuse the pun!)
Offline danny_p
Re: Help! Mk3 golf gti headlights not working!
« Reply #1 on: 20 January 2009, 19:45 »
if it's all of them look at the switch,
all the VW's have gone bar 1.
Offline mattyass
« Reply #2 on: 20 January 2009, 19:46 »
well its just the main beams. Sidelights and everything else are fine
Offline danny_p
« Reply #3 on: 20 January 2009, 19:48 »
what happens if you pull back the stalk for high beam ?
Offline mattyass
« Reply #4 on: 20 January 2009, 19:49 »
High beams work albeit only one as the bulb's gone in one side but they flash or switch on just fine
Offline Mikester
  • Civic Type R
« Reply #5 on: 20 January 2009, 19:51 »
have you checked the bulbs, unlikely they both went at the same time, but the most likely option. If not check the fuse
Offline mattyass
« Reply #6 on: 20 January 2009, 22:21 »
Im gonna check the bulbs tommorrow cheers dude. Should have checked them straight off but didnt really have time tonight and with it being both lights not working i didnt think it would be the bulbs but definately worth a check. I think i'll change the fuses to just in case
