Golf mk1
Fuel Lines
Topic: Fuel Lines (Read 2488 times)
DANO
Fuel Lines
23 June 2004, 08:26 »
Has anybody renewed their fuel line recently? I havea Mk1 Golf GTI and the area around the fuel pump and accumulator is really rusty. I know that some of the parts are obsolete and need making up but has anyone found a place that does them on request?
I am base in Preston , Lancs but would be prepared to travel.
Ta.
hairyarse
GTI forum regular
Re:Fuel Lines
23 June 2004, 17:44 »
Check out our forum for detailed discussion on this topic in the Knowledge Base -
www.campaignregister.co.uk
General opinion seems to be to buy the bits from someone like Automec -
www.automec.co.uk
Other than that I dont think you'll find someone other than independant guys who may make them up for you but shouldn't be too difficult if you buy the right bits.
Hope this helps
richandhazel
Global Moderator
Forum addict
Re:Fuel Lines
24 June 2004, 12:35 »
http://www.campaignregister.co.uk/forum/viewtopic.php?t=833&postdays=0&postorder=asc&start=0
Has anyone ever considered or tried using the plastic pipes from the mk2? I've scrapped two mk2's recently and have made a point of keeping the plastic fuel lines, in case that fateful day arrives that I need to do the ones on my cab.
DANO
Re: Fuel Lines
05 September 2004, 10:28 »
Right, having done a bit of homework on the subject GSF do the pipes from the fuel pump to the accumulator and a company called Automec 01280 822818 do the fuel pipes with the end fitting already in place. I will be purchasing the kit soon!!
Golf mk1
Fuel Lines
