Author Topic: Cheap G60 Synchro ....  (Read 956 times)
Offline Mk2George
« on: 19 January 2009, 15:42 »
Offline topher
  • Administrator
  • fully functioning
Re: Cheap G60 Synchro ....
« Reply #1 on: 19 January 2009, 15:47 »
Quote
I think there were only around 500 syncro's made but havn't seen one as yet with a G60
the guy has no idea what it is.. so it may not even be a syncro. If it is, then it's most likely still running the chocolate setup from the carb version it was converted from.
approach with caution imo.
Offline Mk2George
« Reply #2 on: 19 January 2009, 15:51 »
Yeah I mean at best its a synchro with the G60 engine but is that the same running gear as a Rallye?
sharpie
« Reply #3 on: 19 January 2009, 15:57 »
no there are differences, mainly the rallye/g60 ltd stuff is more heavy duty. gearbox will be different, and obviously brakes.
seems a decent buy if it turns out to be as easy a fix as suggested in the ad - but then if it was really that simple, surely the seller would have sorted it first.
had a wee search to make sure i wasn't talking pish.
danny p says
Quote
also there is a big differance between "some / all "  of the rallye gearboxes compared to syncro ones  the rallye gearbox (ASU)  has a cast iron transfer case whitch is soposed to be stonger  but it also has a sepearate oil to the gearbox  holding only 0.5 ltr iirc so if an oil leack develops  a small leack over time can destroy the transferbox, wheas the G60 gearboxes have ali transfercases and common oil supply so the transfer case can't run dry so easly
« Last Edit: 19 January 2009, 16:04 by sharpie »
Offline danny_p
« Reply #4 on: 19 January 2009, 16:38 »
well it's RHD so it'll be running the ghey RHD manifold and downpipe.    has all the tell tale sings of been a syncro,  but it's proably got the chocalate rod change gearbox in there,   so there is £600 + to spend converting it to 02C    if you want reliable fun
all the VW's have gone bar 1.
Offline billinjah
« Reply #5 on: 21 January 2009, 02:56 »
im going to have a look ill post back what i find.
