Author Topic: Tyre pressures 16/205/55  (Read 13796 times)
Offline AlexKid
  • Living well is the best revenge.
« on: 18 January 2009, 17:25 »
What should they be?  My fuel filler cap is lying.
1.9PSI all round?
1999 MkIV Golf 2.0 8v
Offline Rhyso
Re: Tyre pressures 16/205/55
« Reply #1 on: 18 January 2009, 17:29 »
1.9PSI all round?
why is your fuel filler cap lying?  :huh:
i run 32 front and 30 rears
Offline richw911
« Reply #2 on: 18 January 2009, 17:32 »
1.9PSI all round?
Its 1.9 bar  :wink:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 18 January 2009, 18:17 »
1.9PSI all round?
Its 1.9 bar  :wink:
   :D
Fuel cap says...........................................................
2.1 BAR front, 1.9 rear. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline AlexKid
« Reply #4 on: 18 January 2009, 19:04 »
I see.  I guess I must be reading my fuel cap wrong.  I have 1.9 bar all round.  2.1 in the fronts?  Isn't that too much?
Offline Rhyso
« Reply #5 on: 18 January 2009, 19:13 »
nope - remember the golf's weight distribution is 60% front 40% rear so you need the extra pressure to compensate for the weight  :nerd:
Offline AlexKid
« Reply #6 on: 18 January 2009, 19:23 »
I will see to it that the correct 2.1 at the fronts and 1.9s at the rears are done ASAP.  Thanks for all the help.
Offline AlexKid
« Reply #7 on: 19 January 2009, 16:17 »
Checked my fuel filler cap again today.  1.9BAR front and back with 2 passengers and a suitcase.  Full load 2.1 front 2.6 back.
Either my filler cap is wrong or you guys are.  :undecided:
Offline AlexKid
« Reply #8 on: 19 January 2009, 19:54 »
Can someone clarify this issue many thanks.
Offline richw911
« Reply #9 on: 19 January 2009, 20:00 »
We are never wrong.
 :grin: :grin: :grin: :grin: :grin: :grin:
2.1 BAR front, 1.9 rear In mine  :wink:
