Author Topic: MK2 VR6 help  (Read 5167 times)
Offline sidecarphil
Re: MK2 VR6 help
« Reply #20 on: 22 January 2009, 19:09 »
if i change to a 90 spec loom and fuse box will my MFA and cluster still work ??
is there any thing else i will need ??
will MK3 indicator and wipers storks work ??
Re: MK2 VR6 help
« Reply #21 on: 23 January 2009, 08:08 »
you need a 90spec cluster, stalks and MFA loom as well.  MK3 stalks will fit yep :)
good news is 90spoec loom is very modular so if you say got a car loom from a carb car you could find a 90spec GTI MK2/MK3/Corrado MFA stalk loom and plug that in, MK3 GTI/VR6 fuel pump loom and add that (to go with the VR fuel pump, lines and a MK3 Golf fuel tank, if you use MK2 k-jet you need a 90spec MK2 GTI pump loom & lift pump)
Offline sidecarphil
Re: MK2 VR6 help
« Reply #22 on: 23 January 2009, 14:42 »
but IF i get a complete VR6 corrado and strip that , i will be able to use the dash , wiring loom , engine , box , brakes , subframe , radiator , every thing i want ??
if i have read correctly ??
Re: MK2 VR6 help
« Reply #23 on: 23 January 2009, 16:01 »
pretty much, just remember some things like the lighting plugs will be different :)
Offline sidecarphil
Re: MK2 VR6 help
« Reply #24 on: 23 January 2009, 16:52 »
yeah but i can trim them from the MK2
thanks rubjonny you truelly are a legend
just need a left hooker corrado VR6 rear end smash  :wink: :wink:
Offline sidecarphil
Re: MK2 VR6 help
« Reply #25 on: 31 January 2009, 07:13 »
so i have bought a doner car :)
http://link.marktplaats.nl/225387205
am i correct in thinking that i can use the interior loom / fusebox / indicator storks /steering column /dials
BUT keeping my MK2 dash board ???
rubjonny , Please do you have a MK2 and MK3 interior wiring diagram :) ,in colour if pos ???
cheers Phil
Re: MK2 VR6 help
« Reply #26 on: 31 January 2009, 10:32 »
you can use pretty much all the loom from that, but the headlighlight and rear screen heater loom will be wrong, as will the dials and heater blower bits and random stuffs liek the interior light, door pins etc ont be the same.  quite a lot of the existing car loom will unplug from the fusebox looms, and often will plug straight back into the replacement loom, but you might have to splice a wire here & there.
If you fit mk3 clocks then thats 1 part sorted, and you would want to anyway so the rev counter works properly!
when i converted my mates 88 to 90 spec, i hardly had to splice anything.  but then i was using a MK2 90spec loom :grin:
Hopefully my fusebox faq should have everything you need to get this done, but pm me your email addy and i'll send you some diagreams :)
Offline sidecarphil
Re: MK2 VR6 help
« Reply #27 on: 31 January 2009, 13:58 »
i have an uprated headlight loom so i only really need sidelights and a feed for dip and main , so thats no problem
as for it little bits inside the car , i can cut the original plugs off and soldering them to the MK3 loom :)
as for the clocks i will be using MK3 , so no problems with wiring there
and i will use the MK3 fusebox
will wire up the elec windows wiring and elec mirrors from the MK3 and fit the motors inside the MK2 mirrors
can i use the MK2 rear subframe or do i use the MK3 ??
what rad do i need ?? is it better to buy a corrado one ? and will that fit either the MK2 or MK3 rad mount ??
