Author Topic: Rust around the petrol cap  (Read 1567 times)
Offline bowdie
« on: 18 January 2009, 00:26 »
Got the dreaded rot around the petrol cap and since I'm planning on keeping the car for the long haul, figured I should get it fixed properly.
Does anyone know if an off the shelf repair panel is available, or do I need to find a shell with no rust in this area (a challenge) and then cut out the part I need ready for rewelding into mine?
Any help/suggestions appreciated
Thanks
Ian
Offline Jay
  • balding fat cvnt
Re: Rust around the petrol cap
« Reply #1 on: 18 January 2009, 00:29 »
There were some 3door arch panels on the bay for £10 each, not sure if they had the petrol cap filler hole.
or you can cut out the rot and weld in a replacement steel plate.
Put up a pic so we can see how bad it is.
Offline bowdie
« Reply #2 on: 18 January 2009, 00:31 »
will try and get a pic tomorrow (today!)
edit:
just found this http://www.panels.magnumcarpanels.co.uk/acatalog/VOLKSWAGEN.html
« Last Edit: 18 January 2009, 00:35 by bowdie »
Offline Jay
  • balding fat cvnt
« Reply #3 on: 18 January 2009, 00:40 »
If it's only that part that's rust, it shouldn't be too bad cutting the old one out and welding the new one in, providing you know how to weld ofc  :grin:
http://www.panels.magnumcarpanels.co.uk/acatalog/info_95_25_52_2.html
Offline dTEA
  • back in an MK5
« Reply #4 on: 23 January 2009, 18:07 »
handy site that...might make a note of that un...you just never know  :rolleyes:
Edition 30 / T5 T32 Kombi
Offline maplesyrup
« Reply #5 on: 23 January 2009, 19:12 »
I've just found some on ebay from Imperial panels, about £30 posted.
Definately better to graft in a panel than fiberglass it.
Hope this helps.
"when the going gets weird the weird turn pro"
