General discussion
twin cam vw engines
Topic: twin cam vw engines (Read 3881 times)
Dizzie
Forum addict
Make friends with your fast
twin cam vw engines
22 June 2004, 00:00 »
someone explain to fielder why our 16v and 20v engines only have 1 cam pulley on the end.
Mk4 Golf 150PD
golfvr6
Guest
Re:twin cam vw engines
22 June 2004, 00:11 »
The exhaust cam is driven by the sprocket via the cam belt, the inlet cam is driven via a chain that links to the back of the exhaust cam.
later vw polo 16v engines actually have 2 cam sprockets.
golfvr6
Guest
22 June 2004, 00:24 »
Here is an example
An Audi 20v engine,
The chain is at the sprocket end, on the 4 cylinder it will be on the other end on the cams.
The principle is still the same, one sprocket drives the exhaust cam, then a chain links both exhaust and inlet cams.
Hope that helps
Fielder5757
Guest
22 June 2004, 00:40 »
LOL ok diz you win.........For now
Dizzie
Forum addict
22 June 2004, 10:44 »
too much time looking at Jap engines did that to you fielder
Mk4 Golf 150PD
kniterider
Guest
22 June 2004, 20:44 »
heres a pic of my 20v four cylinder head, as you can also see the cambelt drives the exhaust cam, which is linked at the other end by a chain and sprocket to the inlet camshaft hence the 'sohc' lookwhen you see the belt just driving one pulley on the 'open side'
enjoy!!
lol
Gaz
oh yeah turn pic around 180 degrees and it would look like it did on the car!! lol
Dizzie
Forum addict
Reply #6 on:
22 June 2004, 23:41 »
and it would be impossible to work 20 valves with only 1 cam
Mk4 Golf 150PD
Gambit
Forum addict
Reply #7 on:
24 June 2004, 14:06 »
Quote from: Dizzie on 22 June 2004, 23:41
i read somewhere that some engine manufacturer where able to work 16v's with one cam
or somehting bizarre, ill try and dig it out
Last Edit: 24 June 2004, 14:07 by Gambit
Gambit
Forum addict
Reply #8 on:
24 June 2004, 14:10 »
honda crx esi & mazda mx3 are both 16v SOHC engines
and ford have a 2.0 8v twin cam!
Last Edit: 24 June 2004, 14:11 by Gambit
mk1
2ltr16v turbo (now with programmable EFI)
Reply #9 on:
24 June 2004, 18:58 »
And the Triumph dolomite sprint had a 16v engine and used one cam to operate the valves, and used the same cam lobe to open the inlet and exhaust valves
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
General discussion
twin cam vw engines
