Author Topic: Annoying plastic bit under passenger seat  (Read 1544 times)
Offline Blackdeathdiesel
« on: 17 January 2009, 17:55 »
Hi
I have a really annoying plastic bit under the passenger side seat of my 3 dr TD140. Every time I have to push the seat back it dislodges and ends up flapping around the car.
Has anyone else experienced the same problem and is there an easy fix that I am missing. It doesnt appear to be broken and theres no obvious way of fitting it.
Thanks
Offline R32UK
Re: Annoying plastic bit under passenger seat
« Reply #1 on: 17 January 2009, 18:14 »
Open window. Throw out useless black plastic bit. Works every time :grin:
Offline LaserBlue
« Reply #2 on: 17 January 2009, 19:11 »
yeah i know what you mean.. also their is another plastic part that covers the wires on the floor, ppl catch it with their feet when getting out the passenger side, always keep replacing it lol
« Reply #3 on: 19 January 2009, 17:57 »
Thats the one I mean, the one that covers wires up, its about 100mm sq.
I would throw it away but then Id be left with a hole in the floor :cry:
Maybe I should have bought the old mans hot hatch with too many doors :grin:
Offline LaserBlue
« Reply #4 on: 19 January 2009, 22:32 »
well you could try applying some glue.. not the real sticky type but the non permanant stuff carpenters use
when i have time ill try it, would hold it in place from people knocking it all the time, can alway remove it with a little force if need be
« Reply #5 on: 20 January 2009, 08:13 »
Thanks, will give that a go.
