Author Topic: when coming down a hill.....  (Read 3993 times)
Offline player.777
« on: 16 January 2009, 23:04 »
...and the gear selected it too low, does it do more damage to the clutch/ fly wheel pressing the clutch to the floor, in gear and coasting down with your foot to the floor, or putting it neutral, and coasting down out of gear???
Offline Rhyso
Re: when coming down a hill.....
« Reply #1 on: 17 January 2009, 14:14 »
i just let it coast in gear - shouldnt do any damage as the engine is not under full load
Offline Ben Lessani
« Reply #2 on: 17 January 2009, 14:24 »
Depends on whether its a steep hill and you are controlling your speed, or if its a motorway and your controlling fuel economy.
Either way, engine braking does no damage, and high gear for fuel economy.
Offline player.777
« Reply #3 on: 17 January 2009, 15:48 »
but even if you put it in 6th, coming down a hill near me, the engine is still effectively pulling the car back, so not getting as much speed down the hill- so not being as economical, as I have to put your foot on the accelerator down before I would if I were coasting?
Offline Ben Lessani
« Reply #4 on: 17 January 2009, 16:43 »
But if you're in gear and not on the throttle, the car doesn't have to use *any* fuel to keep it turning over, gravity and the wheels do that. If you take it out of gear, yes you will go faster, but then the car has to use fuel to keep it idling - thus using more fuel.
Offline player.777
« Reply #5 on: 17 January 2009, 16:52 »
mmm interesting point.  Ok i'll give that a go- BUT when coming down the hill, I'm getting 199mpg anyway, which is the highest the readout goes- I suppose I could still get more miles to the tank doing it your way. Ok I'll see what happens. Thanks for help me out.
Offline player.777
« Reply #6 on: 17 January 2009, 16:56 »
so coming back a bit- does either method do more damage to the clutch than any other??
Offline Ben Lessani
« Reply #7 on: 17 January 2009, 17:06 »
Shouldn't do a bit, only if you were riding the clutch half up the whole time.
When the gear is engaged, there is extremely little clutch wear, in fact none - only if you were at full throttle towing something when it might slip and wear I guess.
Offline player.777
« Reply #8 on: 17 January 2009, 17:09 »
Got you. Great. thanks mate
