Author Topic: LH Trackrod & Ball joint  (Read 1369 times)
Offline Oilburner
« on: 16 January 2009, 16:32 »
I have play in my O/S front trackrod end :sad: For some reason none of my local motorfactors can supply me with one, more worrying is that they are all adamant the track rod and ball joint on the passenger side are separate, and I know they are not and trackrod/ball joint come as one piece.
The only place I can find that can get one is the local dealer who want £40 + Vat :shocked:
Surely there must be somewhere on line i can get it from?
Can one of you guys point me in the right direction??
Rich
1987 - MkII Golf GTI 16v
2005 - MkIV Golf GTTDI 140
Re: LH Trackrod & Ball joint
« Reply #1 on: 16 January 2009, 17:55 »
you cant get the fixed ones anymore ;)
Offline Ben Lessani
« Reply #2 on: 16 January 2009, 19:20 »
I take it your driving a pre-90 version then?
Offline Oilburner
« Reply #3 on: 16 January 2009, 19:26 »
Sorry chaps - cardinal sin of no vehicle details...
Yes, 1989 8v....
So you have to buy seperate? that will be why the motorfactor dont list it! had a right argument with them about it too...  :lipsrsealed:
Mind you, not that they stock the rod, only the end...
« Reply #4 on: 19 January 2009, 15:13 »
all man8ual racks have a fixed passenger side track rod from the facvtory, PAS models have adjustible ones on both sides. The fixed rods were discontinued years ago, so you need to get an adjustible rod+end and set it to the factory length:
edit: this figure is for power steering, I know this is different from the figure quoted in the haynes (410mm).  However I cannot confirm what length the manual track rod is on RHD MK2s, as the Bentley obviously is for LHD models, and Elsawin only covers PAS track rods.  My advice is to measure the length of the fixed rod after you take it off and use whichever figure is closest to the old one :)
« Last Edit: 19 January 2009, 15:21 by rubjonny »
Offline Oilburner
« Reply #5 on: 19 January 2009, 15:21 »
Cheers - inspecting mine a little closer it looks like its a seperated job already, so i may be able to get away with just getting a new joint; unless its seized up :sad:
Thanks for the info, i will ensure i set it to the correct length :cool:
