Author Topic: cam belt change  (Read 951 times)
Offline boo
cam belt change
« on: 15 January 2009, 21:31 »
what parts do i need for a cam belt change
on a abf 16valve golf thanks
Offline richieboy
Re: cam belt change
« Reply #1 on: 16 January 2009, 11:05 »
You should replace the timing belt and the tensioner, also you will need an array of tools so that you can get the crank pulley and the water pulley off which can be a nightmare, think you need a xzn bit and a socket holder.
SKF Tensioner from GSF:
13141, 051-109-243A @ £32.50
Belt from GSF:
13109B, 048-109-119G @ £18.50.
These parts are for a ABF engine with auto tension adjuster (mine is a 96 and has auto tensioner) which will need to be tightened up to correct tension with either circlip pliers or there is a special tool that laser make for about £10
Offline boo
Re: cam belt change
« Reply #2 on: 16 January 2009, 21:14 »
cheers for the reply and the part numbers the cars a 97 p reg
im not changeing it my mates doing it as part of the deal
when i got the car of him  :grin: he said buy the parts ile
do for you
