Author Topic: pls help---------temp sensor poor mpg ......  (Read 7302 times)
Offline Rhyso
Re: temp sensor
« Reply #10 on: 15 January 2009, 21:55 »
ta m8 dam stealers better have it in stock tomorrow.
u know the g 12 thing do u pour that into that think that looks liek a feed and expansion tank on the left of the engine in a see through round thing. sorry dont knwo the technical term for it
they will do or they shouldn't be dealers!
its called the expansion tank - you will need to dilute the G12 slightly - ratio's are on the back of the bottle
Offline nadlad
  • Building Surveyor MRICS
Re: temp sensor
« Reply #11 on: 15 January 2009, 22:00 »
alright cheers.  its called a expantion tank .....am a civil engineer by trade been designing a lof of HVAC systems at work f**k knows why i called it a feed and expansion tank!
<<<Big Build Thread>>>
Offline Rhyso
Re: temp sensor
« Reply #12 on: 15 January 2009, 22:06 »
well it does regulate the coolant around the system so i guess technically you are correct
i'd suggest buying a Haynes manual - not great but will give you a better idea of what things are and where they are  :smiley:
Offline nadlad
Re: temp sensor
« Reply #13 on: 15 January 2009, 22:11 »
will the haynes manual tell me how to change the boot/lock and handle over?
Offline richw911
Re: temp sensor
« Reply #14 on: 15 January 2009, 22:12 »
Yep  :smiley:
Offline T_J_G
Re: temp sensor
« Reply #15 on: 15 January 2009, 22:41 »
Weren't on the back of bottle. If your changing the temp sender you'll only lose about 100ml if that. Really easy t do.
Offline richw911
Re: temp sensor
« Reply #16 on: 15 January 2009, 22:51 »
It was on the G12+ i got from VW  :undecided:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: temp sensor
« Reply #17 on: 15 January 2009, 22:52 »
Yeah, will only spill a table spoon, tops, when changing the CTS!  :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline dai-cymru
  • 1989 MK2 16V
Re: temp sensor
« Reply #18 on: 15 January 2009, 22:55 »
defo on the bottle of genuine VW G12 as i filled mine up today its 2 parts coolant to 3 parts water
Offline T_J_G
Re: temp sensor
« Reply #19 on: 15 January 2009, 22:58 »
Weren't on mine, just double checked. Mine was G12 plus plus....
