Author Topic: Just wanted to make sure, 8v backbox on 1.8 GL...  (Read 1743 times)
Offline Shady Pioneer
  • graphic designer.
« on: 15 January 2009, 14:06 »
It fits without any modification right? lol!
Offline boneybradley
  • Back in a Mk3...
Re: Just wanted to make sure, 8v backbox on 1.8 GL...
« Reply #1 on: 15 January 2009, 14:20 »
same bore and same fitting....should be no problem
  • graphic designer.
« Reply #2 on: 15 January 2009, 14:21 »
I was waiting for you to confirm :D
Thanks buddy, I'm sure it would be ok, just got someone who'll be selling a Scorpion Twin Pipe backbox for an 8V next week, £50 it's mine :)
  • Back in a Mk3...
« Reply #3 on: 15 January 2009, 14:24 »
Who....oh and contact number (I will double check it will fit your 1800 for you  :wink: and if not it will definately fit my 8v)
  • graphic designer.
« Reply #4 on: 15 January 2009, 14:44 »
Haha, me don't think so :P thanks for then adivce though man :)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 15 January 2009, 17:09 »
Hang on...  My 1.8 has the middle silencer on the striaght pipe and no middle box near the beam...  where as all my GTI engines have the big middle box and a straight through pipe from the cat.   So the 8v/16v backbox would not fit on my 1.8 (i tried and failed) it would need a bit of pipe welded on.  Mabey the later 1.8 is diffrent but i would check this first.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
  • Back in a Mk3...
« Reply #6 on: 15 January 2009, 17:26 »
my last gti (94 model) had the exhaust from my old 94 driver and it was direct fit (ok the gti did come originally with a larger box near the axle but the shape and fitment was same....)
  • graphic designer.
« Reply #7 on: 15 January 2009, 18:00 »
Right so hold on then, what are we saying? LOL!
If this backbox is off a 8V GTI, are all 8Vs the same in that area or not?
I know under my car I've got 2 boxes near the back and then the cat near the middle/front.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #8 on: 15 January 2009, 18:21 »
buy it shady, try and fit it. if it doesnt fit, sell it to boney!
Its a win-win.
LL ;)
  • graphic designer.
« Reply #9 on: 15 January 2009, 18:21 »
Its a win-win.
LL ;)
That is true, very true indeed, even if he doesn't buy it I'm sure someone will, good man :D
