Author Topic: Are monty 2s stamped with BBS....?  (Read 3767 times)
Offline player.777
« on: 14 January 2009, 22:14 »
yes/ no?  Should the w8 wheels I'm picking up tomorrow to be stamped to- am I right thinking they are BBS too?
Offline Rhyso
Re: Are monty 2s stamped with BBS....?
« Reply #1 on: 14 January 2009, 22:27 »
fairly sure mine are stamped with BBS - hang on i'll check.................
ooo wait its a bit dark and i'm scared of the dark  :laugh: :laugh:
Offline player.777
« Reply #2 on: 14 January 2009, 22:47 »
Go on!! Get out there!!!  Also, what is the offset of the monty2s???
Offline Rhyso
« Reply #3 on: 14 January 2009, 22:49 »
i'm thinking 42/45  :undecided:
Offline black_mk4_golf
« Reply #4 on: 14 January 2009, 22:52 »
the audi tt quat wheels ive got are 35 offset so will b sitting just nice in them archs !
an yea they are bbs wheels
-  Black Golf Gti 2.0 mk4  -  Private plate  -  Black Blue Colour Concept recaro leather interior  - gti badge done with a blue ' i ' to match interior  -  R32 spoiler  - 25th Anni front splitter  -  fk highsport coilovers  -   18" nouvo black diamond cut  -
Offline player.777
« Reply #5 on: 14 January 2009, 22:52 »
right, ok so if the new ones are 37which I am told they are)- I need (if monty2s are 45)- 8mm adapters???  I think minimum size is 15mm so the stance will be as bit wider but shouldnt really be a 'rubbing' issue.- I hope this is all correct!!
Offline player.777
« Reply #6 on: 14 January 2009, 22:54 »
Ah ok great thanks!! What width adapters have you got on those??  At least I know it can be done without getting close to the limits.
« Reply #7 on: 14 January 2009, 22:58 »
none 35 is the max really   with offsets its all opersite   the lower the number the more they stick out
dnt think you can get a spacer to be 8mm  goes in 5's ithinks........
Offline player.777
« Reply #8 on: 14 January 2009, 23:01 »
so if the offset is 37 on the new wheels- does that mean they are closer to the arches?  How close??  If I can get a 10mm adapter (which I think is too thin) that would then make a total size of 27??  Would that still fit under the arches???
« Reply #9 on: 14 January 2009, 23:02 »
really you wanna make erm sit out a lil bit ova the standard look any way  if u find they rub your f**ked bruv  as you cant make somit go bak inwards if you get me    so your better off with a bigger numberd offfset as you can space them out after which is less work
i know there is a place in dagenham in essex ( elite http://www.elitedirect.com/ ) near me that can shave the centre bore down to rase your offset thou .......
