Author Topic: mk3 vr6 knocking  (Read 1818 times)
Offline vr6bigsteve
mk3 vr6 knocking
« on: 14 January 2009, 19:51 »
hiya guys am just after a point in the right direction, have just put my 2.9 vr lump in my mk3 and all is connected up, runs and idle is spot on, put sounds very knocky, thought this may have been down to the point the that the head was port and polished, so all was bone dry wen it went together left it to idle for a time and has got quieter but don't want to keep running it up if it is going to do long term damage, water is flowing fine tho bottom hose is getting warm but not as hot as top, thought i would add that point don't know if it makes a diff, tho do keep removing cap to release the air from the system. (when turned off ) lol. so any ideas as like i said dont want to fcuk it up b4 i have chane to get it on the road.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: mk3 vr6 knocking
« Reply #1 on: 15 January 2009, 17:05 »
First off,  knocking can mean alot of things, ultimatly its total engine failure so be carefull before you go revving the t*ts off it.  Now the VR6 engine layout means it does sometimes suffer from a bit of piston slap which is a knocking noise from the pistons when its cold, very bad cases it will only quieten slightly when warm,  go for a drive, if it knocks harder on acceleration and goes quiet on deceleration.. thats piston slap, not something you need to worry about too much!   If the knocking gets worse when you rev the engine and carrys on during deceleration,  it could be the bottom end, but unlikely!   Any noise from the top end should be a lighter ticking/tapping noise.  The timing chains can make a tapping/light knocking noise.
First off,  get the air out of the pipes, they can be a pain,  start the engine up and run it,  take the top off the coolent bottle (while cold) and massage the top and bottom pipes with your hands, pumping them.  do this at idle, then rev it to about 2500 rpm for about 60 seconds and pump the pipes again,  you should see a bit of air bubble out of it,  by the sounds if it you dont have much air in there,  then run it up to full temp (Keep the interior blower on full HOT at all times) just incase it does overheat.   put the top back on the bottle, sit in the car and watch it warm up to full temp, Watch that gauge though!! wait for the fan to kick in and check it cools it off and doesnt run above half way.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
« Reply #2 on: 15 January 2009, 20:57 »
please make sure ur heaters are on other wise u will get air traped in the heater matrix lol
Offline vr6bigsteve
« Reply #3 on: 17 January 2009, 09:18 »
thanks guys will do this,
