Author Topic: NEW INJECTORS  (Read 1053 times)
Offline jake
NEW INJECTORS
« on: 13 January 2009, 19:55 »
if i uprgrade my injectors on a 1.8t would i notice any improvement in performance
if so any recommendations on which injectors to buy and price?
If you upgrade the injectors you dont need to upgrade anything else with it do u? :undecided:
Offline MaXXeH
  • Golf MK5 GTI
Re: NEW INJECTORS
« Reply #1 on: 13 January 2009, 21:00 »
no but will prob kill ur engine if not remapped to it.
Offline jake
Re: NEW INJECTORS
« Reply #2 on: 13 January 2009, 22:53 »
has anyone ever done this mod? :huh:
Offline damo_ b
Re: NEW INJECTORS
« Reply #3 on: 13 January 2009, 23:24 »
sure loads of people uprate the injectors but only if the stock ones run lean
if thats the only mod you are planning then its pointless as just upgrading the injectors will only cause over fuelling
not sure what then flow rate of standard injectors are  if for instance they are 380cc and you upgrade to 440cc then you will over fuel by 14%(not good). you would need a remap.
read here http://www.rceng.com/technical.aspx
horsepower sells cars
torque wins races
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: NEW INJECTORS
« Reply #4 on: 13 January 2009, 23:29 »
No need, mate.  Std injectors will flow enough fuel for 4 BAR fuel pump & 4 BAR FPR. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
