Author Topic: NEVER...  (Read 2004 times)
Offline Jay
  • balding fat cvnt
NEVER...
« on: 12 January 2009, 20:31 »
... let your fuel tank get less than 1/2 on the red (less than 1/16th? of a full tank)  :shocked:
Ss-sst-tu-ut-tte-err-r-rrr-rr mania :laugh: :cry:
If you ever let your fuel get that low and start experiencing crazy stutter, change ya fecking fuel filter first  :grin:
Mine was probably due anyway and luckily I had a spare  :grin:
I was thinking the worst things were happening all the way home even after I filled up, the car was going nuts when I tried putting my foot down in 3rd, 4th or 5th and in 1st and 2nd it felt like it wasn't even firing on all cylinders  :shocked:
This is NOT an experience I want to relive... I suggest having a spare fuel filter in the car or at home!
Are there any easy ways to clean out the fuel tank to get rid of the 20yrs of crap?
Offline Ben Lessani
Re: NEVER...
« Reply #1 on: 12 January 2009, 20:34 »
I don't let mine get below 1/4, that's mainly because the gauge only really operates between 1/4 and 3/4's. So I have no idea if its actually a 1/4 tank or if its empty :tongue:
Offline JC
  • Back in the North.
Re: NEVER...
« Reply #2 on: 12 January 2009, 20:39 »
Jay - Stating the bleeding Obvious - 2009  :grin:
Offline Jay
  • balding fat cvnt
Re: NEVER...
« Reply #3 on: 12 January 2009, 20:44 »
I had to chance it because I was running late for work  :sad:
You forgot 2007 and 2008  :tongue:
Honestly, I thought it was completely fookered because it had been hard rain most of the day and it felt like it wasn't running on all cylinders.
I guess I was so relieved it was only the fuel filter I had to post to let it out my system  :tongue:
Offline edpryce
Re: NEVER...
« Reply #4 on: 12 January 2009, 21:27 »
i'm never off red
Offline Organisys
  • Old and Slow...
Re: NEVER...
« Reply #5 on: 12 January 2009, 21:31 »
I've run my daily under the red a few times..no problem....
Except the MFA says I only ever do 10mpg  :grin: Should really fix the vacuum pipe.
Offline Ben Lessani
Re: NEVER...
« Reply #6 on: 12 January 2009, 21:51 »
My MFA always thinks I'm getting 1/3 of what I really am.
But I'm confused, I can understand if it over reads the MPG, due to a leak. But how to can under read the value - surely it would need even more vacuum?
I thought it was the speed sensor and vacuum sensor on the back of the clocks which was nuked, rather than the hose itself.
Offline jamie_pyrite
Re: NEVER...
« Reply #7 on: 12 January 2009, 21:53 »
If it's a carb engine, you could do the old trick of covering up the air intake for 10 seconds while holding the revs up, then letting go. Sucks the crap through   :cool: Had to do it once when mine wouldn't start when ran near empty.
Offline AdamMk2
  • Beautiful
Re: NEVER...
« Reply #8 on: 13 January 2009, 18:06 »
i'm never off red
How I know the feeling, red is a cool colour. stick in the red.
It makes it a challenge.
I will live to regret this comment  :laugh:
Offline monzablue16v
Re: NEVER...
« Reply #9 on: 13 January 2009, 20:31 »
Mini didn't used to have a gauge. Well it did it was a mag light through the fuel cap :laugh: always had a jerry can in the boot, just in case :)
