Author Topic: Drilling airbox?  (Read 3730 times)
marcus123
Drilling airbox?
« on: 19 June 2004, 09:51 »
easy job? ???
how do i do it? ??? :-\ :D
cheers :-* :D
Offline GavG60
  • keep my credit cards away from me please :-(
Re:Drilling airbox?
« Reply #1 on: 19 June 2004, 10:34 »
have you taken the resonater out yet mate?
marcus123
Re:Drilling airbox?
« Reply #2 on: 19 June 2004, 11:30 »
alrite matey! ;)
im well duff at mechanic type work! :D
whats a resonater? ???
Offline Dragon6
Re:Drilling airbox?
« Reply #3 on: 19 June 2004, 14:11 »
remove the bottom of the airbox you will see a trumpet shaped piece where air is sucked inb at the front of the airbox remove this (resonater) then drill some holes I did 20mm along the inner wing side of the airbox,fit a K+N panel filter and bobs your uncle job done and sounds a treat when given some stick.. :)
marcus123
Re:Drilling airbox?
« Reply #4 on: 19 June 2004, 14:29 »
cheers oakie :D
Blue MK2
Re:Drilling airbox?
« Reply #5 on: 19 June 2004, 16:25 »
dont drill it. its a waste of time
golfvr6
Re:Drilling airbox?
« Reply #6 on: 19 June 2004, 16:28 »
Only a waste of time if you don't add a k&n or something similar.
Offline so1o
Re:Drilling airbox?
« Reply #7 on: 20 June 2004, 03:16 »
When i bought mine it already had a cut out instead of holes. The inner wing was cut aswell. Panel filter H&R, i think was fitted. I must say over 4k rpm its sounds very nice, also been told this by various people.
Well worth it for the sound alone, btw mines a 2.0 16v.
Solo
marcus123
Re:Drilling airbox?
« Reply #8 on: 20 June 2004, 12:00 »
mk3 2.0 16valve engine solo?
Offline so1o
Re:Drilling airbox?
« Reply #9 on: 20 June 2004, 15:31 »
Nah, as far as im aware its a 9a from a passat, lovely engine.
