Author Topic: STOP - Brake Fault - Check Service Manual?  (Read 1585 times)
Offline JamieGTi
« on: 12 January 2009, 16:15 »
Car started shouting this to me this morning...
Also the ABS light is on and the handbrake light is flashing
Any idea's what it could be? Hope its not expensive  :undecided:
Offline djianb
Re: STOP - Brake Fault - Check Service Manual?
« Reply #1 on: 12 January 2009, 16:17 »
this happened to me last week. did ur brakes fail and does ur brake pedal go soft (like ur clutch)
Offline JamieGTi
« Reply #2 on: 12 January 2009, 16:19 »
Doesn't feel like any less braking efficiency
did you get it sorted?
Offline djianb
« Reply #3 on: 12 January 2009, 16:21 »
yeah i had a brake fluid leak on the rear pipe (eroded) check for leakage, normally ul hear like air escaping (hissing) wen u pres the brake pedal in
Offline JamieGTi
« Reply #4 on: 12 January 2009, 16:25 »
Ok thanks, i'll check that.
How much was the repair if you remember?
Offline djianb
« Reply #5 on: 12 January 2009, 16:28 »
pipe cost 15 quid brand new from vw, mobile mechanic charged me 40 quid for fitting it and bleeding the brakes
Offline JamieGTi
« Reply #6 on: 12 January 2009, 16:42 »
Not that expensive then, I could do the mech work myself.
I hope this is the problem and not something more expensive.
Feel sick after all these things that have gone wrong with it lately  :sick:
