Hey guys,
I've searched to death but can't find 100% definitive information. I'm wanting a little information about all this engine changing business. From a whole bunch of reading (correct me if I'm wrong), but there's a few different variations on how people go about this,
The ABF is a 2.0l 16v and runs on an electronic fuelling system (Motronic), as standard produces around 150 BHP.
The KR is a 1.8l 16v and runs on a mechanical fuelling system (K-Jet), as standard produces around 140 BHP
Those that are currently running digifant systems benefit from merging the two looms, and swapping out the block and head from the ABF and have the option to retain the 020 or upgrade to the 02A from a Toledo.
But those with a KR can use their existing head and fuel management, but simply swap out the larger 2.0l block? Which as an end result produces around 160 BHP?
To keep on track, is the above correct?
What happens with the subframes, I know you can move the whole MK3 and go wide track with uprated brakes, but then you end up with 5 stud front wheels. Can you still keep the MK2 subframes (F+R)?
Now, what about if you had an EV like myself, its a 1.8l 8v K-Jet. Could I just pinch the 2.0l ABF block and settle for around 10-15 BHP more? Does anyone have a link to a project like this? Or would it be more beneficial to ditch the entire 8v head and block, retain the existing fuel pump and lines, grab a KR head and bolt it onto the 2.0l ABF block?
Handy thread
