Author Topic: Rear wheel bearing advice needed.  (Read 779 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 11 January 2009, 14:01 »
Fitted a good quality rear wheel bearing to the N/S/R of my 1990 16v yday. How many miles should I leave it til I check & retighten?
Offline 8 valver
Re: Rear wheel bearing advice needed.
« Reply #1 on: 11 January 2009, 19:02 »
There isnt realy a set mileage to check the bearing if they have been adjusted right they should go to the next service without any adjustment .I like to adjust them up leaving a small amount of play in the bearing hope this helps :smiley:
Offline andc1
« Reply #2 on: 11 January 2009, 20:02 »
ive never needed to re adjust the bearing once they are in! dont tighten up to much and leave a little play wobble and they should be fine
