Author Topic: wheel spacers  (Read 2213 times)
VeeDubGTI16v
wheel spacers
« on: 18 June 2004, 15:03 »
anyone know if theres an adaptor for pcd 5x112 to 4x100
and whats the offset on a mk2?, cos the wheels i have got in mind are ET36.
« Last Edit: 18 June 2004, 15:05 by veedubgti16v »
vwsystems
Re:wheel spacers
« Reply #1 on: 27 June 2004, 01:36 »
not sure on the offset i'd have to ask my bro.....
but what i do know is that only use proper quality spacers........ ballanced ones with proper evely drilled bolt holes not cheap universal ones..... which will throw the ballancing out and cause major vibratons! and also they wont sit nice on the hub this adds the the problem...... runout etc etc......
use proper makes like eibach.......
cheap and nasty one
proper eibach one!
nogama3
Re:wheel spacers
« Reply #2 on: 01 July 2004, 09:10 »
I know that H&R do adaptors from a 4 stud to a 5 stud not not the other way around, speak to C&R Enterprises, they are pretty good with advice.
Eibach spacers are the best as previous post suggests, I had universal ones on which made my wheel fall off + broke my caliper at the same time. Very dangerous.
Offline Gambit
Re:wheel spacers
« Reply #3 on: 01 July 2004, 09:21 »
if your wheels are et36, then a spacer can add upto 15-20mm on top of the offset and therefore pushing them out as far as et16!!
VeeDubGTI16v
Re:wheel spacers
« Reply #4 on: 01 July 2004, 13:34 »
i better see if you can get them 10mm then. isnt the offset for a mk2 et25?
Offline Gambit
Re:wheel spacers
« Reply #5 on: 01 July 2004, 13:39 »
mk2 offset is et35 mate
VeeDubGTI16v
Re:wheel spacers
« Reply #6 on: 01 July 2004, 13:46 »
bah >:(
Offline Gambit
Re:wheel spacers
« Reply #7 on: 01 July 2004, 13:49 »
if they are 15's then you might get away with it on 195/45 rubber and rolling the rear arches
