Author Topic: MK2 8V- 2.0 AGG PLANNED  (Read 7353 times)
Offline richard s
Re: MK2 8V- 2.0 AGG PLANNED
« Reply #10 on: 11 January 2009, 21:19 »
yes 2e can be used also there is one more code from the mk3 that can be used but not sure of it
Offline danny_p
« Reply #11 on: 11 January 2009, 23:52 »
2e  was the old favoret but there starting to run out so everyone is munching at the AGG supply now
all the VW's have gone bar 1.
Offline ozegti
« Reply #12 on: 12 January 2009, 21:53 »
Is this the same if I've got an 8v K Jet? i can get an engine cheap, but need to work out what else i need.
Offline Jay
  • balding fat cvnt
« Reply #13 on: 12 January 2009, 22:03 »
Just the bottom block isn't it?
VW BUSH
« Reply #14 on: 12 January 2009, 23:09 »
Use ADY/Sharan Engine, b different.
Compression ratio is special.
I had a 2e block on of my old Mk2s, was cool but a little thirsty
Sorry to jack your thread  :laugh:
Offline 8 valver
« Reply #15 on: 13 January 2009, 21:52 »
Why is it ness to use a 2e dizzy? dose the pb one not fit?
Offline MarkS
« Reply #16 on: 14 January 2009, 00:44 »
Is there any advantage to using a 2e/AGG bottom end compared to a bored out 1.8?
Alllllllso is there a rough figure of the torque increase by adding a 2.0 bottom end?
« Last Edit: 14 January 2009, 00:49 by MarkS »
Offline paultownsend
« Reply #17 on: 14 January 2009, 01:14 »
i got 145lbft
Offline mk2 AL
« Reply #18 on: 14 January 2009, 22:27 »
PB dizzy is too thin (smaller diameter) so wont fit in the hole properly. You can make up a spacer ring to make it sit in the hole nice (used to be able to buy them from somewhere) but easier to just fit 2e dizzy.
I have recently done a 2e bottom end conversion with schrick 276 cam and slightly modded head, defo has more grunt but tbh for the money it's cost me to build i was expecting more and wouldnt bother doing it again. But i needed an engine and quick for a trip to the ring.
Money is now being saved for 20vt conversion only a few months after doing the 2e stuff  :undecided:
Offline danny_p
« Reply #19 on: 14 January 2009, 22:40 »
agg dizzy also only gives 1 pulse per revolution,   so would only fire one cylinder
