Author Topic: Cleaning door & boot Returns  (Read 4278 times)
Offline 1st_Golf
« on: 09 January 2009, 22:30 »
I have the use of a steam cleaner for the next wee while, which has some pretty fine nozzles with it. Is there any reason that I shouldn't use it to clean the returns, and if not, anything to be avoided/regreased? (apart from the obvious moving parts that are visible)
Cheers!
Offline Curious
Re: Cleaning door & boot Returns
« Reply #1 on: 10 January 2009, 16:04 »
Never used steam so cant really help other than say be careful.
Will you be using just the steam or will you be using APC first then steaming it off?
I would be careful around any edges which have glue, the steam may just remove it.
Offline Dan J
« Reply #2 on: 10 January 2009, 23:54 »
steam cleaning door/boot shuts is fine :wink: keep it moving and dont hold the jet too close,be carefull of wireing etc.
when dry aplly a good layer of sealant /wax then re-grease moving parts etc.
