The reverse mirror is pretty crap also, only works intermittently, i always endup useing the joystick
If you want my tuppenceworth, they are pretty crap I wouldn't bother.... As for the puddle light, they give off a low level yellow light, hardly illuminates the ground much. Personally don't think you are missing that much.
Quote from: AndyC on 10 January 2009, 21:18The reverse mirror is pretty crap also, only works intermittently, i always endup useing the joystickMine works perfectly every time. It only works when the mirror control is set to the L position. I am wondering in the times where you find it doesnt work it is because your mirror control is not set to L when reverse gear is used.
