Author Topic: Head Gasket.  (Read 2499 times)
Offline Rodriguez
Head Gasket.
« on: 09 January 2009, 11:21 »
Ok ladies and gents.  I've got my paranoid head on today.  The chariot is running fine after I replaced the starter yesterday, but I am now worries about me engine.
Ok symptoms:  Coolant level and temp remains ok and no sign of contamination but seems a liitle pressurised.  Dipstick reveals clean oil but I'm getting a small amount of mayo on the cap. And I know its cold but the white steam from the exhaust seems a little excessive.
Now am I worrying about nowt considering the car's age and the weather we've been having or is there further checks I can do, short of poaching a compression tester from somewhere.
Cheers in advance.  Hope everyone's having a reliable new year :evil:
Offline sidecarphil
Re: Head Gasket.
« Reply #1 on: 09 January 2009, 11:55 »
if you got a good amount of antifreeze in the car
take the plugs out see if they are the same colour as your antifreeze
Offline Conker
Re: Head Gasket.
« Reply #2 on: 09 January 2009, 12:48 »
The condensation out of the exhaust is pretty mega at the moment due to the temp. Mine looks like a power station first thing in the morning!! When my headgasket went, I had no mayo, but loads of steam out the back even when the engine was really hot, but the main way I coul tell (excluding the compression test) was that water consumption was huge.  A full coolant tank would only last 30 minutes before it was dry.
If your water level isn't changing, its prob just steam.
Re: Head Gasket.
« Reply #3 on: 09 January 2009, 12:50 »
all sounds perfectly normal to me, the coolant system is designed to pressurise to raise the boiling point, and a bit of mayo is normal when only doing short trips.  bit of  steem from exhaust also normalk, cold air makes it look worse than it is plus water is a natural byproduct of combustion.
Offline Rodriguez
Re: Head Gasket.
« Reply #4 on: 09 January 2009, 15:39 »
Thanks guys
Just finished me second bottle of scotch now, so the demons are silent again :wink:
Offline tobz.
Re: Head Gasket.
« Reply #5 on: 09 January 2009, 16:09 »
 :shocked: Jeez second bottle of scotch finished by 15:30!!! I'd be more concerned about that than my head gasket.
You got any pics of your dad's split ?
Offline my white golf
Re: Head Gasket.
« Reply #6 on: 10 January 2009, 10:52 »
it all sounds fine to me, i was warming my car up the other morning and scrapping off the ice when a woman walking past said my gosh it looks like its on fire!
old school rules
Offline Mk2George
Re: Head Gasket.
« Reply #7 on: 10 January 2009, 11:07 »
Hehe yeah, all sounds familiar to me too, letting mine warm up on a morning to defrost and after about 5 minutes i have trouble finding the car amidst all the steam :) My old 8v was tha same too - completely normal
Offline ozegti
Re: Head Gasket.
« Reply #8 on: 25 January 2009, 17:42 »
Right, this sounds ok to me then. I pulled my spark plugs a few days ago and they were all dry, but grey in colour. I've had mayo occasionally on the cap, but the main thing is, it's leaking from the T piece with the top hose. Need to sort that out. Might need to change the water pump as well. :( I'm off to london tomorrow, so we'll see how it goes!
Offline Ben Lessani
Re: Head Gasket.
« Reply #9 on: 25 January 2009, 18:26 »
Dude you should see what I found when I removed my rocker!
Compression testers are only like £20 from Halfords, I bought mine ages ago and thought I'd only ever use it once - its been one of the best diagnostic tools I have owned, I've used it tonnes of times!
I don't reckon my HG is damaged at all, but I did have a torn breather that was probably just sucking in water, along with the fact my airbox was also wet inside!
