Author Topic: AIRBAG FAULT WARNING MESSAGE  (Read 5213 times)
Offline ben1.8T
Re: AIRBAG FAULT WARNING MESSAGE
« Reply #20 on: 19 January 2009, 11:13 »
just leave it mate, its not an mot fail, so if you can put up with it, then do so :grin:
You couldnt put up with it you said it done your head in so much so that your getting a new car  :grin:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline Rhyso
« Reply #21 on: 19 January 2009, 11:14 »
I need to get hold a new plug for under my drivers seat!
Had it checked at the weekend and the wires under the seat are fooked!
Just don't know whether I can be bothered to spend £50 on a new plug!
which plug mate i got a donor car?
the one in the floor i believe he is on about mate - its the yellow connector for the seat; its rectangle and most likely buried under a few bits and pieces lol
Offline dai-cymru
  • 1989 MK2 16V
« Reply #22 on: 19 January 2009, 11:23 »
under a few hubs and driveshafts i expect  :smiley: will have a look later
Offline Matt_Mk4
« Reply #23 on: 19 January 2009, 11:40 »
Yeah - it's the one on the floor!
Under the drivers seat
Whoever had the car before me has cut the plug off and taped them together with electrical tape!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #24 on: 20 January 2009, 10:54 »
i got the yellow plug runs under the carpet somewhere, does anyone know if it runs to a connector somewhere else?
Offline Rhyso
« Reply #25 on: 20 January 2009, 10:58 »
off the top of my head i would suspect it runs under to somewhere in the dash - not 100% if there is a seperate airbag controller or if its controlled through the CCM (central convenience model)
Offline DANNYGCL
  • but plug thumb and jizz cookie)
« Reply #26 on: 20 January 2009, 11:09 »
Ahhh, My light comes up on my right hand side (near the headlight switch) when i start the car, goes off for a second then comes back constantly, its been annoying the life out of me but i have to explain, when i got the car it was disconnected and the owner before didnt know about it but the owner before that might have been around to know what the fault was, problem one, will never be able to get hold of him problem two, what do you guess think it is, ive been told its something under the seat and if so where is that connection under the seat.
Cheers Gents  :cool:n Ladies  :kiss:
usually I am listening to my own pistons trying to make a bid for freedom through the sump
Offline Rhyso
« Reply #27 on: 20 January 2009, 11:22 »
see here
http://www.golfgtiforum.co.uk/index.php?topic=102077.0
disconnect the battery and leave for 15 minutes before attempting anything
Offline DANNYGCL
« Reply #28 on: 20 January 2009, 11:45 »
see here
Thanks very much :), got new leather seats being put in so may as well wait till they arrive n go from there :)
Offline Rhyso
« Reply #29 on: 20 January 2009, 12:01 »
see here
if you still got problems let me know as i got full VAG COM and can scan and clear the codes - notice you're only in Cardiff  :smiley:
