Author Topic: AIRBAG FAULT WARNING MESSAGE  (Read 5209 times)
Offline djianb
Re: AIRBAG FAULT WARNING MESSAGE
« Reply #10 on: 14 January 2009, 23:09 »
my car is cat D so i'm taking it is due to that
Offline richards golf
« Reply #11 on: 17 January 2009, 20:32 »
Hi
Had same prob with mine took it to local garage they plugged it in had a look found no faults and just reset it.
No more annoying Boings!! :smiley:
Offline mk4luke
« Reply #12 on: 18 January 2009, 09:34 »
i have this problem with my car,i think its the connector in the drivers side seat airbag but if not its only £50 for a new one from www.airbagsforsale.com or just go to a breakers and steal one :rolleyes: :grin:
i didnt bother to get it as the car is being sold :grin:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #13 on: 18 January 2009, 10:30 »
Dijan - I thought you'd bought that fault code reader??
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline dai-cymru
  • 1989 MK2 16V
« Reply #14 on: 18 January 2009, 10:41 »
pluggin it into vag com this weekend sooooo fingers crossed i won't need one!! are they hard to fit or?
depends which one
drivers side is a 5 minute job (20 if you include waiting 15 after you've disconnected the battery)
if its the
 seats urm its a difficult job though most likely the wiring under the seat that is the problem
how long a job rhyso  :evil: :evil:
Offline djianb
« Reply #15 on: 18 January 2009, 12:47 »
yeh i did worked a treat!!
Offline Rhyso
« Reply #16 on: 18 January 2009, 13:26 »
depends which one
if its the
not as long as it took you to decide before you gave up  :tongue:  at least i got the airbag off  :smug:
Offline Matt_Mk4
« Reply #17 on: 19 January 2009, 08:58 »
I need to get hold a new plug for under my drivers seat!
Had it checked at the weekend and the wires under the seat are fooked!
Just don't know whether I can be bothered to spend £50 on a new plug!
Offline mk4luke
« Reply #18 on: 19 January 2009, 10:58 »
just leave it mate, its not an mot fail, so if you can put up with it, then do so :grin:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #19 on: 19 January 2009, 11:13 »
which plug mate i got a donor car?
