Author Topic: Erattic / stuttery engine note  (Read 778 times)
Offline maxp
  • J reg 8v digi gti
« on: 06 January 2009, 18:21 »
For a few days, when idling, rather than a constant purr, the exhaust note has been jumpy/erratic.
It also affects when pulling off (put foot down and it stutters then about a second later gives some power to me)
Also (!) it was doing it on the motorway today over 65mph it would stutter/do the same.
Its quite disconcerting so any advice appreciated.
Reminds me abit of when you first start driving and you *almost* stalled it, it would go all jumpy
EDIT: Sorry its a 8v GTI (digifant)
« Last Edit: 06 January 2009, 20:03 by maxp »
Offline Conker
Re: Erattic / stuttery engine note
« Reply #1 on: 06 January 2009, 19:25 »
When mine did this it was faulty ignition leads.
(PS...  Always remember to state which engine you've got, as it helps with diagnosis)
Offline maxp
  • J reg 8v digi gti
« Reply #2 on: 07 January 2009, 20:18 »
bump for any other viewpoints?
Offline nealey
« Reply #3 on: 07 January 2009, 20:32 »
As said, possible misfire which can be caused by a number of things
Check all the vac pipes are in good condition and not split/adrift.
Also have a look at rubjohhnys tuning guide and get it set up correctly
