Author Topic: hot running problem  (Read 782 times)
Offline rennsport
hot running problem
« on: 06 January 2009, 17:13 »
hi, i've just bought a mk2 16v ('90) and it has developed a problem with the idle revs when warm. whilst cold the car idles at 1,200 rpm with no problems and runs fine, but after 10 mins or so the idle becomes very erratic. the idle fluctuates between 2,000 and 4,500 rpm without any throttle, which of course is unbearable to the extent that you have to switch off the ignition when stationary. when changing gear the revs die normally, so no issues except when stationary or in slow moving traffic.
the throttle is not sticking, i can only assume it's some kind of auto-choke, ecu or ignition fault. has anyone here experienced similar or could have a stab at diagnosing the fault?
many thanks in advance.
Re: hot running problem
« Reply #1 on: 06 January 2009, 17:35 »
1st thing I'd check is the idle switch, make sure the throttle snaps shut to the stop, the upper part moves freely and contacts the switch, they can get a bit gummed up with age.  If its sticky remove the 13mm nut on the top and carefully remove the top arm, give it all a clean then reassemble.  Take care not to trap the spring in the plastic bushes as it will bind up, once workign the top arm should move freely and hit the switch every time you open and shut the throttle.
if that checks out, switch on the ignition with engine off and make sure the ISV buzzes.  It shouldnt make loads of noise but it should have a nice strong humm, you'll feel it if you touch the ISV.  Next check the 3 temp sensors on the side of the head, make sure no wires have snapped or fallen off the sensors.
If all that checks out run the car till hot, then swap the red/yel wire to the other 2 sensors 1 at a time, then go check the dash gauge reads about the same on all 3 sesnors.  You dont have to have the engine on just run it till its hot enough for the dash temp gauge to move with the ignition on.
If all THAT checks out then you may need to adjust the base idle & CO, there is an FAQ post on how to do this :)
Offline rennsport
« Reply #2 on: 07 January 2009, 08:17 »
Johnny, thats a very comprehensive and helpful reply. i shall do as you suggest. many thanks.
