Author Topic: Tapping on wheel - brake related  (Read 907 times)
Offline maxp
  • J reg 8v digi gti
« on: 04 January 2009, 14:48 »
My O/S front wheel has started making a tapping noise that increases in frequency the faster i go.
If i drive with the brake pedal slightly depressed then it stops. It sounds like its going to be new something like new pads or something possibly more sinister?
Thanks!
Offline DOA
Re: Tapping on wheel - brake related
« Reply #1 on: 04 January 2009, 15:45 »
Could be anything, can I suggest you take the wheel off lol?
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 05 January 2009, 08:22 »
It could be one of two things. The most likely is that your pads are rattling within the caliper. Quite common if a little embarrasing. Check the retaining clips/springs are there.
The other MUCH less likely is wheel bearing, but this would be accompanied by a constant rumbling sound from that wheel.
Offline Skiing
« Reply #3 on: 05 January 2009, 17:49 »
This probably sounds obvious, but if your wheel bolts are loose it can make this noise... mine did once when I forgot to tighten one set up for a bit... not my most intelligent moment...  :nerd:
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
Offline Mr Blue
« Reply #4 on: 05 January 2009, 18:04 »
while your there check your hub nuts
Offline Jay
  • balding fat cvnt
« Reply #5 on: 05 January 2009, 20:51 »
Caliper/carries bolts?  :huh:
(never looked into the brakes much, just a thought)
