Author Topic: Oil warning light on 16v  (Read 3070 times)
Offline Rick 16v Mk2
« on: 16 June 2004, 11:58 »
Hello, I hope someone can offer some advice. At low revs on my valver there is no oil warning light. At 1200 rpm the red light flickers erratically. Above 1200rpm the light begins to flash regularly. Drop the revs and the light goes out. A pressure test showed 2.5bar at 2000rpm. Does anyone have any suggestions as to what the problem could be? All help greatly appreciated.
                       Cheers, Rick.
« Last Edit: 16 June 2004, 19:29 by Rick 16v Mk2 »
Offline benjam_in
Re:Oil warning light on 16v
« Reply #1 on: 16 June 2004, 12:21 »
silly question i know but have u checked your oil level?
Golf Mk2 Gti 1988
« Reply #2 on: 16 June 2004, 12:25 »
(I must avoid sarcasm as I need peoples'  help) yes, thank you, I thought of that.
Offline benjam_in
« Reply #3 on: 16 June 2004, 12:30 »
sorry it is something a few drivers do overlook! wasnt trying to get at you just one of those obvious questions u have to ask!
have u looked at the sensor?
Golf Mk2 Gti 1988
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #4 on: 16 June 2004, 12:31 »
Dodgy oil pressure sender maybe ??   ???
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
« Reply #5 on: 16 June 2004, 12:32 »
 ;) No worries mate. Yes, I changed the sensor to no avail. I was wondering if the pressure could actually be too high?
Offline benjam_in
« Reply #6 on: 16 June 2004, 12:37 »
not sure on that one mate. mine normally comes on when the oil is low! (or just at one side of the sump on a round a bout)
Golf Mk2 Gti 1988
  • Valver Bad Boy
« Reply #7 on: 16 June 2004, 12:44 »
Silly question now - is your Dipstick housing damaged ??
I've seen that with other people, and it's resulted in the dipstick going in too far and they've over filled the engine ALOT !
Offline benjam_in
« Reply #8 on: 16 June 2004, 12:51 »
Hmm never thought of that dave, had a caddy at work that the engine blew cos it was overfilled.
Golf Mk2 Gti 1988
  • Valver Bad Boy
« Reply #9 on: 16 June 2004, 13:00 »
It's a common fault on Mk2's, so often people have bodged something to fix it without thinking of the consequences ...
Can lead to either a artifcially high or low reading depending on the bodge !
Check it out
