Golf mk2
Bent big bumper
Topic: Bent big bumper (Read 1881 times)
Justins145bhpMK1
Bent big bumper
15 June 2004, 17:07 »
Hello just picked up a MK2 on an H and am going through the process of restoring it now my MK1 has gone...
Its had a slight shunt at the back and the bumper is slightly bent in . As its plastic Im not sure if its possible to pull it out??
Anyone got any ideas??
Oh and im mising a mirror adjuster knob and a parcel shelf support if anyone has one.
marcus123
Guest
Re:Bent big bumper
15 June 2004, 17:10 »
back rear bumpers are relatively cheap,
if your restoring it id reccomend that you buy a new one,
there only about 50 quid
Dizzie
Forum addict
Make friends with your fast
Re:Bent big bumper
15 June 2004, 19:22 »
I might have a mirror adjuster. if I find it I'll let you know.
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
JMallows
Re:Bent big bumper
16 June 2004, 13:45 »
Hi, Take off the bumper, by undoing the four bolts underneath. Then take off the plastic from the metal bracket, should then be a simple case of pushing it out. Then clip it back on to the metal, and attach bumper back on.
A clever person solves a problem. A wise person avoids it.
Blue MK2
Guest
Re:Bent big bumper
16 June 2004, 23:21 »
might be worth heating it slightly from the inside with a heat gun, then pushing it out
Justins145bhpMK1
Re:Bent big bumper
17 June 2004, 16:43 »
Thanks all ill give it a go!
marcus123
Guest
Re:Bent big bumper
Reply #6 on:
17 June 2004, 16:45 »
oh yeh,
kniterider is sellin a big bumper for only 10 quid!
check it out in the for sale section mate!
Golf mk2
Bent big bumper
