Author Topic: Golf Mk2 280mm brake query  (Read 2388 times)
Offline Dangerboy
« on: 31 December 2008, 10:01 »
Hey folks,
Can anyone give me a definitive answer as Ive been chasing my tail somewhat...  :laugh:
I have a 8v 90spec gti which came with 239's; I have since bought a pair of 256 hubs which I have put on the car along with a set of g60 discs... Im now needing the calipers as well...
question is this... can i fit mk3 288 calipers or do I need specific g60 280mm ones?
Any wisdom or help would be greatly appreciated,
Gary
Offline pro-biotic
Re: Golf Mk2 280mm brake query
« Reply #1 on: 31 December 2008, 10:36 »
288`s have a different mounting location and as such wil not fit you need the g60 caliper as fitted to these models
mk3 gti, some passats, ibiza 2.0 gtis, corrado g60 - girling caliper 54mm piston (vw pn vw part number 357 615 123 & 357 615 124)
basially if your looking for 2nd hand calipers aim for early mk3 gtis, look out for girling 54 and the 2 indentations on the caliper knuckle, the carriers should also fit a mk2 16v hub
some early vr6 golfs had 280s and later changed to 288 - not sure if teh poverty spec gtis followed suit.
new calipers are about £50 each i am sure
Offline pro-biotic
« Reply #2 on: 31 December 2008, 10:56 »
calipers
oh and most fit a larger master cylinder to reduce the pedal travel as the calipers require a little more fluid to apply pressure
Offline Dangerboy
« Reply #3 on: 31 December 2008, 11:14 »
Cheers lads,
Ive got the larger master cylinder and servo sorted out... just wasnt sure about the calipers... ill check gsf and the like for calipers unless anyone on her has a set for sale?
Most appreciated,
Gary
Offline pro-biotic
« Reply #4 on: 31 December 2008, 11:17 »
if your looking for new first port of call would be a dealer as rumor has it they supply exchanges at about £55 quid. i remember finding an online site selling them for 45 but cant remember which one.
ebay has a set supposedly from a 97 vr6 currently on a tenner ha
Offline Dangerboy
« Reply #5 on: 31 December 2008, 11:26 »
Still leave me with trying to find carriers though if i buy new
Offline pro-biotic
« Reply #6 on: 31 December 2008, 11:29 »
oops - think i may have some carriers knocking about - will looksie
