Author Topic: Engine Mounts MK2  (Read 1714 times)
Offline benjam_in
Engine Mounts MK2
« on: 15 June 2004, 16:48 »
Any one know any quick and simple way to change the rear engine mount on me mk2?  ???
ben
Golf Mk2 Gti 1988
Offline floggot16v
Re:Engine Mounts MK2
« Reply #1 on: 16 June 2004, 16:34 »
is it the n/s or os rear?
I found it easier to remove the alloy bracket from the block, then access is a bit easier.
Put a block of wood on a trolley jack under the sump, DONT lift engine with it though, its just to support engine while you work, The other way is to use a scaffold pole cut to fit on lip of inner wing and a sling/rope tied to the lifting eyes on the head.
plenty of wd40 if the bolt is rusted up.
woody
Offline rustynuts
  • God is a DJ
« Reply #2 on: 22 June 2004, 20:50 »
Your just going to have to accept that you are going to lose lots of skin. You will get there eventually.
Offline benjam_in
« Reply #3 on: 23 June 2004, 09:48 »
cheers boys! after a bit of investigation it looks like its the front one thats gone! gunna change that and see if that sorts it first then tackle the beast at the back if its still not sorted!  :P
Golf Mk2 Gti 1988
