Author Topic: Xenon adjustment with VAG-COM?  (Read 3026 times)
Offline Dubbin
« on: 30 December 2008, 23:06 »
Hi,
Can someone explain the correct way to adjust Xenons? I've seen people here mention that the correct way is to use VAG-COM but on top of the lights there are two adjustment screws marked UD (up/down) and LR (left/right). Are these an alternate method or should they be used together?
I've tried the adjustment screws on their own and while they do seem to have some effect the range, when dipped, is still poor.
Thanks,
2013 Golf Mk7 GTI PP, DSG, Pana Sunroof, ACC, 5 Door
Offline gazbutmk5gti
Re: Xenon adjustment with VAG-COM?
« Reply #1 on: 30 December 2008, 23:22 »
are they factory fit, they are self levelling if they are, why do you need to adjust them, you replaced 1?
Revo stg2+ & lots more
Offline Dubbin
« Reply #2 on: 30 December 2008, 23:39 »
They are factory fit and they do self level when first switched on. When I first had the car they were way too high (gettin flashed every night) so I had them adjusted at the dealers. They came back too far over to the left and now on the low side so rather than waste time taking it back I was hoping to adjust myself with the screws.
« Reply #3 on: 31 December 2008, 00:20 »
I see, not sure its something that really should be tackled guessing, be best to get it set up at garage where they have the equipment to align everything spot on, unless you you do have that set up off course :smiley:
Offline john_o
« Reply #4 on: 31 December 2008, 08:12 »
These may help
http://wiki.ross-tech.com/index.php/VW_Golf/Jetta/Bora_(1K/5M)
scroll down to [55] - Headlight Aim Control  :cool:
looks like you adjust the screws then get the ECU to remember the setting
hth
« Last Edit: 31 December 2008, 08:14 by john_o »
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline mrlapou
  • Mean GTi
« Reply #5 on: 31 December 2008, 09:52 »
VCDS (Vagcom) is used to 'switch off' the headlight self level ecu. Then you adjust lights with the screws. Switch ECU back on and it takes new light position as being the self adjust height datuum.
Offline NotNormal
« Reply #6 on: 31 December 2008, 18:54 »
These may help
hth
You have to set the ecu to "adjustment", then manually adjust the headlamps, then press ok on vag-com .
HIH
_____________________________________________________________________
Golf GT170D MK5 - not factory - better
Audi S4 (B6) 4.2 V8 - Noggy blue - (sold)
Offline vRStu
« Reply #7 on: 31 December 2008, 22:22 »
IIRC you should be on a level surface with the handbrake off too.
Stu
