Author Topic: gear linkage adjustment  (Read 1648 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 15 June 2004, 12:41 »
I have searched for this but with no luck :(
Is there any info or "how to's" on how to adjust the gear linkage on my 1989 MK2 16V?
I have recently changed the selector ball, and all things are good on the gerr stick, but it seems that the linkage is out as I am having to really shove the stick left and up to get first, the normal action for first gives me third!
I has been sugested here that the fix for this is the linkage? is this true if so how do i do it, also any other things I should look for that may cause this problem.
thanks
Offline Deefadog
Re:gear linkage adjustment
« Reply #1 on: 16 June 2004, 07:28 »
Anyone? Sorry to seem impatiant but I have to get this sorted by the weekend.  i would like to do it myself, but if I can't find  any info I'll have to take it to a garage :(
Offline richandhazel
« Reply #2 on: 17 June 2004, 10:38 »
Here is some info on how to adjust a mk1 linkage:-
http://www.geocities.com/jonnyguru/vw/shifter.html
Although the mk2 is slightly different, the principal is the same. I found that using the 15mm gap didn't work for a mk2, however after various attempts at loosening adjusting, re-tightening and checking, I eventually got it right.
Offline Deefadog
« Reply #3 on: 17 June 2004, 22:02 »
Thanks for the info, I have booked the car in to a local garage who knows Golfs :) they can sort this out for me and my slugish trake off in first also :)
Thanks again
