Author Topic: Tail Light Bulb Replacement  (Read 5994 times)
Offline Nick W
« on: 28 December 2008, 12:27 »
Hi guys, recently bought a Mk 5 GTi and had off side tail light go. Couldn't see how to change it, so took it to dealers, who kept me waiting for an hour and charged £12 to change it. Two weeks later the near side tail light now gone. How do I change it, do I need special tool? Can any one help. Thanks
Offline TagnuT
  • Edition 30
Re: Tail Light Bulb Replacement
« Reply #1 on: 28 December 2008, 15:09 »
Have you looked in your manual?
 or try this :-
http://volkswagen.msk.ru/electro/g5/g5_94_eng.pdf
save it to your comp then open it.  :smiley:  Its from the maitenance section at the top of the page. Page 71 onward.
« Last Edit: 28 December 2008, 15:12 by TagnuT »
Bye Bye Edition 30
Offline Nick W
« Reply #2 on: 28 December 2008, 16:41 »
Thanks TagnuT,
I'm used to a fairly simple plastic clip arrangement to remove the light cluster. The two nuts holding this cluster in place looked too meaty for my liking and I was concerned they might be holding the car together. Reassuring to see from the guide that they are indeed securing the rear light clusster in place together with a perculier plastic probe adjuster thingamy-bob. Will have a bash at this tomorrow. Incidentally, my manual has none of this detail. Thanks again.
Offline ub7rm
« Reply #3 on: 28 December 2008, 18:32 »
I was a bit dubious at taking the car apart to change a bulb as well but its piss easy and less hassle than the usual arrangement.
2020 BMW 128ti
2017 Golf GTD Estate
Offline Steve Baker
« Reply #4 on: 28 December 2008, 20:56 »
It is straight forward, just try to avoid dropping the nuts behind the trim as you remove them once undone!  :smiley:
Offline Nick W
« Reply #5 on: 02 January 2009, 20:17 »
Thanks guys, changed the bulb this am and as you say it was very straight forward. Feel a bit of a fool for having to ask, but as I said, the nuts holding the light cluster appeared unnecessarily large for the job.
Offline Rollini
« Reply #6 on: 15 April 2009, 20:04 »
what bulb is it that i need to get to swap it myself? is there i code or something i can go into halfords with?
Offline TagnuT
  • Edition 30
« Reply #7 on: 16 April 2009, 15:57 »
1. Have a look in your manual. 2. The bulb will have its rating stamped on the metal part of the bulb. 3. Or you can go to Halfords they have a listing for cars/Bulbs
Bye Bye Edition 30
Offline Rollini
« Reply #8 on: 16 April 2009, 16:20 »
1. the manual doesn't say what bulb it is  :cry:
2. i don't have the wrench thing at work to undo the bolts to get to the bulbs to check
3. halfords are rubbish! the website is as clear as mud and i just wanted an idea before trekking in there and asking the spotty 16yo
cheers tho  :wink:
Offline TagnuT
  • Edition 30
« Reply #9 on: 16 April 2009, 20:39 »
The other option is to use the car finder on the powerbulbs website:-
http://www.powerbulbs.co.uk/bulb_finder.asp
 :smiley:
Bye Bye Edition 30
