True. This is why I left a few wires with bullet connectors incase the relay fails...and it has failed twice in the past.
Rain water will eat up the relay and wires so protect them well. Ive heat shrunk the lot. So far so good.
i soldered every connector then i heat shrank the connections then loom taped them all up
i have a spare relay in the boot but i think with the maths i did for the V A and R means the raley shouldn't burn out
i used fused relay's that is why they arn't on the wiring diagram
does this really make a difference if using standard bulbs as when i am driving it looks like i use candles instead of bulbs
yes because i checked and i had 7.2V at the back of the bulb's with the engine running
now i get full 14.2 V with the engine running
