Author Topic: Lost Power after remap!  (Read 5209 times)
w0ffle
« on: 24 December 2008, 10:09 »
p
« Last Edit: 18 November 2024, 19:03 by w0ffle »
Offline Steve_PD
Re: Lost Power after remap!
« Reply #1 on: 24 December 2008, 10:10 »
coilpacks, boost leaks... thats about as far as my knowledge goes so I'll leave the rest for someone else  :embarassed:
Get it plugged into vag-com see if it throws anything up  :smiley:
w0ffle
« Reply #2 on: 24 December 2008, 10:12 »
p
Offline damo_ b
« Reply #3 on: 24 December 2008, 10:14 »
running higher boost will show up weak pipes so check that first
horsepower sells cars
torque wins races
Offline Steve_PD
« Reply #4 on: 24 December 2008, 10:16 »
have a nose round make sure everything is tight
Offline T_J_G
« Reply #5 on: 24 December 2008, 10:17 »
Check the coilpacks too.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #6 on: 24 December 2008, 19:44 »
All the re-map does is expose weak links which were there before the map, but you didn't notice because it was running low boost etc.  ;)
AUM's do have a known thirst for new coilpacks, however it'd be best to get it VAGCOM'd first.  ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
w0ffle
« Reply #7 on: 26 December 2008, 15:16 »
p
Offline rheady
« Reply #8 on: 29 December 2008, 15:10 »
What petrol did you have in the car?? remaps seem to need higher octane fuel than normal 95ron.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 29 December 2008, 17:57 »
remaps are done to specific petrol octanes so I doubt it's that
