Author Topic: 8v digi timing  (Read 1632 times)
Veedubgt18v
8v digi timing
« on: 14 June 2004, 18:14 »
i have just done the timing on my 8v digi j plater, using a strobe gun. before i set it the v shaped groove on the flywheel (i painted it white) was at the front of the hole you view it thru, almost out of site. i rotated the distributor till it was in the middle of the hole.
is this ok? or do i need to do anything else. i had to rotate the distributor about half a centimetre round, i forget which way tho.
ta ed
vwsystems
Re:8v digi timing
« Reply #1 on: 14 June 2004, 23:51 »
i'm not sure how its done........ what i do know is that once its more a less spot on the ecu retards and advances the timming! ie so it doesnt matter if its really bang on!
and as far as i know you can only time it at idle!
Offline davidhawkins_78
  • Valver Bad Boy
Re:8v digi timing
« Reply #2 on: 15 June 2004, 16:40 »
Silly question, but why did you set the timing - surely this was done during your rolling road tune @ AMD ???
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
VeeDubGTI16v
Re:8v digi timing
« Reply #3 on: 15 June 2004, 16:44 »
they didn't tune or diagnose anything, it was just reading of power figures
