Author Topic: Dizzie?  (Read 1691 times)
Offline Martz
Dizzie?
« on: 14 June 2004, 13:15 »
Have you pics of that dashboard in your MK2? Would be good to see.
Offline Dizzie
  • Make friends with your fast
Re:Dizzie?
« Reply #1 on: 14 June 2004, 13:58 »
that ok?
« Last Edit: 14 June 2004, 13:58 by Dizzie »
Mk4 Golf 150PD
Offline Dizzie
Re:Dizzie?
« Reply #2 on: 14 June 2004, 14:07 »
dash cost me ?45 from the scrappy. I pulled it out of a 98% complete mk3 driver. took the dials, stalks, matrix. the lot basically. the only bits that were missing were the ashtray that I blagged from another scrappy and the glovebox handle. I had to buy those new from VW. I then told the stalks for ?10.
Took me about 6 weeks on and off over xmas on my drive. about 6 days solid work though. the cutting alone took me a day. The wiring is easy enough. they're all the same colours. bolt in the new matrix so the controls work. weld in the support bar. I used the mk2 clocks for now cos I was getting TT ones anyway, plus it was almost impossible cos mine was a k-jet mk2.
I have loads of pics of the process of it.
Mk4 Golf 150PD
marcus123
Re:Dizzie?
« Reply #3 on: 14 June 2004, 14:32 »
fookkin hell,
thats real impressive you did that all your self,
looks like a good job 2,
did you have any prior knowledge of doin that dash conversion?
or did you jus get stuck in and do it yourself?
cool either way 8)
Offline Dizzie
Re:Dizzie?
« Reply #4 on: 14 June 2004, 23:40 »
yeah I did everything apart from the welding of the support bar. Took me 3 hours to remove the mk3 dash in the scrapyard seeing as I'd never removed anything in a mk3 before. I just looked for screws and pulled bits off. Took me another 2/3 hours to remove the mk2's dash. then plonk it in and start cutting it down so it fits.
I read 2 articles on it on the net, but both did things in a different way. in the end I did it another way still!
I just got stuck in. It's not perfect yet, but I'm hoping the mk4 cab one, that is exactly the same, but has a different texture to it will be spot on. there's still a gap round where it meets the screen and small holes down the sides where I overcut them. Also the screen blower isn't completely airtight. I plan to fibreglass a section to fix that.
I'll upload those pics and link to them tomorrow. I can't be assed right now.
Mk4 Golf 150PD
