Golf mk1
which glue?
Topic: which glue? (Read 5022 times)
raferackstraw
which glue?
18 December 2008, 09:27 »
hi peeps which glue should i use to to fit door seal rubbers to my cabby?
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Dinky
Guest
Re: which glue?
18 December 2008, 20:30 »
Oooo..thats a good question as I just stuck abit of silicone on abit that had split once...worked a treat..but would be a handy thing to know for future...
Dinx
PERFECT PAINT
Re: which glue?
18 December 2008, 21:29 »
Tetrosyl stuff is good value , 3m is the brand everyone knows but its a bit "quilted toilet tissue" if you catch me drift . . .
This will worl perfectly well . .
http://cgi.ebay.co.uk/Tetrosyl-PU7-Polyurethane-Sealer-Adhesive-Black-310ml_W0QQitemZ260332660153QQcmdZViewItemQQptZUK_Body_Shop_Supplies_Paint?hash=item260332660153&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Cut the cone off at a 45 degree angle right near the tip and squeeze a thin bead along where you need it . Do it last thing of an evening and masking tape the rubber in the position you want in . Will be rock hard next morning
Hope that helps , maybe try finding a good spraystore supplier near you ? They will have all these bits and peices in stocf for you . .
raferackstraw
Re: which glue?
18 December 2008, 23:47 »
thanks very much for reply will get some soonest
Ben Lessani
The poor mans MK2 Haynes author
Re: which glue?
19 December 2008, 00:47 »
Evostick Impact Adhesive
That's the stuff I attached my sunroof seals with. Infact, I use it for everything.
PERFECT PAINT
Re: which glue?
19 December 2008, 11:45 »
Ever stuck a midget to ceiling ??
LITTLEGADGI
Re: which glue?
Reply #6 on:
19 December 2008, 21:27 »
TRY STIKA FLEX ITS USED 4 WINSCREENS. STICKS LIKE S!%T TO A BLANKET
Wayne
Sir Postalot
Re: which glue?
Reply #7 on:
13 January 2009, 13:43 »
Evostick is your best bet.
Golf mk1
which glue?
